THRU Bug
Greetings,
I am running a new Gio version 2.0 software and have noticed that the odd time the THRU button will ignore channels.  If you hit 270 THRU 274 it will only select 270 + 271 (for example).  If you where to type 270+271+272+273+274 everything works.   This does not happen all the time and sometimes the THRU for the same channels will work.  If it helps, I am using Live Table showing Active Channels.
I am asking if this is a know bug as the LD who is here was working at another venue last week with an EOS and said they had the same issue.
