How does one Target UNIT #? if i have 22 units on a pipe. i dont want the channel number in the unit, i rather label it the UNIT #? make sense? i didnt see a target for Unit #..
i'm not sure i understand. you want to see the channel label instead/additionally to the channel number? that should be possible with a field: just set it to Label. and then of course you would have to set the name "Unit 5" as label in patch.
is that what you meant?
when you originally layout a pipe of lights using array, it automatically puts a unit number in the center, or is that a CHANNEL number? i changed them to their CHANNEL NUMBER from the LD. Now i would like to change them back, easily, to their UNIT number 1 thru ?. there is NO Target saying its a Unit Number verses a Channel Number or any other Record Target. i hope i am making sense.
Also- how do i merge a magic sheet from my desk top into the EOS onstage? thank you.
