OK, here's something that I was trying to find a quick way to achieve - it might be possible, but I couldn't work out how to get there.
Say I have a range of cues within which I want to look for any instances of a particular channel having a non-zero intensity and increase/decrease those intensities by a fixed amount (e.g. I want to lift all the non-zero levels of a particular channel by 10% throughout a range of cues). I know I could select the cue range, and individually find examples of a channel at a specific level and use the {replace with} softkey to change it to a new level (either relative or absolute). But that would have to be repeated for every different level which that channel is recorded at within the cue range. Is there a way to do a blanket relative increase in level across a channel (or range of channels) regardless of what the current recorded intensities are (as long as they're non-zero)?
Hope I've explained that OK! :-)
