1) request - manual cue. is it possible for the % of the cue to show as it does it timed cues?
B] oddity - part cue- one part is timed, one part is manual. When GO is pressed, intensity parts of the timed cue execute, but only if the intensities are going up. If the intensity values are going down, they do not change until the faders move, and then only with the fader.* Is there a way to make this work so the timed up and down both execute when the cue is executed?
Molly
ZinZanni Seattle
*2.0 software. I have made sure they are in the correct part of the cue. I've tried asserting, switching around which part is manual and which part timed. Yes, I've used a macro for a workaround.
