Hi all
I had an interesting issue with gio console the other day whilst programming and thought I share to see if it is a common problem or a deeper issue.
Firstly the show only used conventionals and approx 9 scrollers so nothing fancy.
The console is a GIo with software version 2.0 loaded
Ok so after programming for about 6 hours for a show that night I was playing back the cues when I noticed something peculiar happen. The cue wouldnt completely finish loading and would not turn yellow in the displays but stay red however it would count to 100% then when executing the next cue same thing would happen only now having 2 cues stay red in the displays.
on pressing "goto cue" then the number the cue would load and turn yellow however the cue would not actually load properly and the red cues would still stay red.
after releasing going to cue out and clearing everything in the programmer and then running the cuelist same thing would happen.
The fix seemed to be to turn the console off leave it off for a few minutes and then turn back on and all was ok.
So I am curious if anyone else has had this issue or knows the underlying cause and a fix for it other than turning the console off...
[edited by: beneboi at 6:41 AM (GMT -6) on Fri, May 3 2013]
