This may be a feature request but here's my situation.
I have a custom fixture (a LED spacelight) with 3 separate intensity channels and if you dim to below 30% the fixture will turn off.
At the moment I have created a custom curve that jumps to the 30% dmx value on the patched fixture at 1% to accommodate this. Is there a way to make a custom curve a part of the fixture profile so I do not have to take the extra step in programming to add that curve?
I've tried playing with ranges, and if the fixture only had one intensity channel that would do it for me, but since there are 3 intensities the editor doesn't treat the custom ranges in the same way as if it has one channel, the automatic virtual master intensity messes it all up, and I can;t edit the ranges of the virtual master either.
Am I making any sense?
