Hi ETC
a few things (some have been mentioned before)
The ETC document Facepanel Shortcuts has an error:
1) it lists ESCAPE & ENCODER PAGE KEY for locking the face panel, AND SHIFT & ENCODER PAGE KEY for locking the face panel.
SHIFT & ENCODER PAGE will actually post the that button to the command line.
2) Shift & UP, SHIFT & Down, Shift Left, Shift Right to move/resize columns is in Patch doesn't yet work. (It would help if the paperwork indicated this is for Patch ONLY.
3) SHIFT & LOAD will clear the contents AND unmap a submaster fader. Shortcuts says first Shift & Load will clear contents; second Shift & Load will unmap the fader. This is NOT the case for submaster faders.
Thanks ETC
Andrew Riter
Chan Centre for the Performing Arts.
