Is there any way to "tap sync" the rate on an effect on an EOS/ION If not could it be a feature request? or be able to set the rate based on BPM?
There is currently no way to Tap Sync. I requested this feature over a year ago. You can however, put the effect on a fader and control speed of the effect that way.
Tap Sync is a feature requested by many others.
I'm sure Anne will confirm, but I believe this is on the list for v2.1
Graham
Close Graham!! We are targeting Tap Rate concurrent with some other effects work in the feature release just after 2.1.
a
Always good to add a disclaimer ;-)
