In programming on OLE (both Eos Family and Element versions), I can not create subgroups. I tried both live and blind. I was using the keyboard 'Shift + /'.
Is this feature enabled in OLE or did I miss a step?
Version 2.0.1.9.0.41
You want to the keyboard shortcut for Shift which is 'Z'. We use the standard keyboard 'Shift' key for other functions.
according to the hotkey overview ( http://www.etcconnect.com/docs/docs_downloads/miscdocs/Eos_Family_v2.0_Hotkeys.pdf ) Shift is Z. so if you use Z + / you will get a ( or ).
EDIT: Steven beat me to it...
Thanks guys. I knew it was something easy that I was overlooking. Appreciate the assist.
