Element Mac 2000 control issue
I use moving lights on element, ion often, I'm running into an issue controlling mac 2000 performances. Namely that on the beam effects wheel I am not able to select within a FX type.
The wheel has an open position, frost section 1% to 100%, prism and "beam expander". I am able select the frost effect but cannot find anywhere in the ML control (expanding everywhere I can see) to tell the unit I want something within the frost range which has a number of DMX values on the fixture.
I hope that makes sense, anyone know a way around this? On the ion I would just use the physical encoder in all likely hood, but I don't have that as its an element.
  • On a console with encoders, press and hold [Shift] while spinning the encoder which will give you control within the Frost setting.
    Using the ML Controls, expand the Beam FX category to show the level wheel associated with it.  Then click or touch in the green area above or below the center line of the wheel.  This is fine control which also controls the values within the frost setting.
