Today, I updated my Ion from 1.9.11 to 2.0.1. I noticed something that struck me as odd. When I am on the Live Channel tab, in any Flexi mode, I can not zoom the display. Format + Level wheel, and Left-click scroll wheel do not zoom the display. The same applies if I use format to go to Live Table. All other tabs seem to zoom as they are supposed to.
When using Direct Selects and Magic Sheets, can sneak be used? I was reading the manual, and there was a note about using sneak with direct selects but it confused me a little bit.
[Chan][2][Sneak]<Time>[2]{Intensity Palette 3}
That syntax is used when clicking on a direct select? Does this also apply to using Magic Sheets.
Also I noticed that the Console sounds turned on after the update.
