DMX Flicker/Pulse
I have just recently done a large production on an EOS console with ETC Net3 Gateway utilizing 4 universes of DMX.
I had DMX flicker/pulse across all universes within the low range of addressing from 1 - 50. . Whilst trying to ascertain the problem, I contacted my local support, Andrew Maher, Jands Pty Ltd, in Sydney, Australia. Andrew brought another gateway down and this did not rectify the issue, so he proceeded to locate another console from a local production house, Chameleon Touring Systems. We swapped over consoles and gateways and loaded the show file and still experienced the exact same problem.  It was then decided to reassign new addresses to dimmers and moving lights higher in the unisverse and this resulted in the flicker disappearing  and the full system becoming stable.
I along with two of my other colleagues, strongly feel that there is some sort of software glitch whereby a signal is being sent out within this low range of addressing.
Has anybody else had this issue?
Regards
Adrian Wright
Lighting Supervisor
National Institute of Dramatic Art
Sydney, Australia
