Patch bug
Hi
I found a problem while patching. (it has not always been there)
When I try to patch a range of channels using THRU I can´t patch
e.g.: 121 THRU 125 @ 513 ENTER.
The command line says: Error Channel list is empty
If I type: 121+122+123+124+125 @ 513 ther3 is no problem.
I´m quite sure that I usually uses THRU (as described in the manual) and that is has worked before.
I´m working on software 2.0.1
Best regards
Anders Kjems
