Network glitch between Primary/Backup takeover
Hello,
Experiencing a little bit of oddness that I was wondering if anyone has come across before. Our setup is as follows:
2 x Gio (Primary/Backup)
1 x RPU (Client)
1 x Eos (Client)
4 x NET3 4-Port Gateways
Connected through unmanaged switches.
All running 2.0.1.9.0.41
When the primary console disconnects, the backup takes over as expected with no change to the DMX outputs. However upon booting from the primary console shell back into primary mode, all DMX outputs snap to 0 for about 0.1 - 0.2 seconds (this is before pressing the take control button on the primary console). The same happens again after pressing the take control button on the primary console when the showfile has finished transferring from the backup, all DMX values go to 0 for a brief moment.
Anyone seen this/know what the cause might be? I've not seen this when transferring between backup to primary before.
Tom
