So as you all know weve had our share of crashes recently, but finally I traced one of them down. In blind if you try to delete a multi part que you may have some trouble. This is what happens Delete Q # Q only enter, once you do this part 1 pops up (on the command line) if you hit clear at this point your desk will most likely kick you out to the shell. At least thats whats been happening with us.
Good Luck
