Dealing with many many LEDs
I am in the process of purchasing about 300 feet of LED Strip lighting. We intend to, in the end, purchase at least double this amount, which puts us in the range of about 4k dmx addresses for LED tape alone. I will be posting some of these questions over on the ETC forums but help here would be appreciated as well.
I am looking for a "simple" way to control it over the in house lighting network. Sadly, Artnet isn't really an option as it would require a total overhaul of the network as it is set up to ETC standards (http://www.etcconnect.com/Community/wikis/products/knowledgebase-etc-network-ip-addresses.aspx) in the 10.x.x.x range rather than the Artnet allowed 2.x.x.x range.
So, the house console is an Ion with 3072 outputs, about 500 of them are used up with the lighting so there isn't really enough room for the intended expansion of the LED installation. However I really like how this system works. The ability to turn on only specific pixels or to grab a group and edit only those, while still having the virtual media server is really really cool and allows for everything I want the system to do.
As far as consoles go, if I were to add another Ion (or Gio or Eos) to my system, or an rpu for that matter, would that increase the outputs I could use on my system? Or would I still be limited to the 3072 allowed by the Ion?
If the Ion limits the total outputs I could have within the system, if I were to add Chamsys setup to my system, would there be a way to fire the Chamsys cues off of the ion?
PJ
  • My first question is...
    Do you really need to have unique individual control over 600'+ of LED tape?
    Is it split up in some sort of mirrored layout (i.e. 300' of LED tape down House Left and House Right?)
    If the answer to this is yes, then that makes your channel count more reasonable.
    If you can make it into smaller groups (4 groups of 150', all able to do the same thing,) it keeps reducing your channel count. What I mean is that if you don't need each LED to be uniquely controllable (like for a video matrix,) then repeating segments make much more sense, and allow you to still do chases and such, but they will repeat around the room.  This may mean it's possible to fit it into your existing ION setup.
    If you need unique control... From the ETC side of the product world, and cost aside, I'd look at the Mosaic line. You can link several of them up together to get the 4000 channels of control you want, they can speak over the sACN/Net3 network, and once you have the Timeline (a sequence of events affecting the LEDs) programmed that you want, you can fire them off using either a DMX input from the ION into the Mosaic device (DMX 1 at full triggers Timeline 1, DMX 2 at full triggers Timeline 2, etc,) or you can send Serial over UDP network commands from the ION to the Mosaic (Timeline 1 start, Timeline 1 pause, Timeline 1 release, etc.)
    Downside is, you have to program the Timelines first, and it isn't a "console" that you can grab things on the fly and change it up, you have to use Mosaic Designer to make the changes. Upside is, it is independent of your show files, and you can, within the limits of it's memory, have as many Timelines as you would ever want. Plus it has some interesting onboard effects that can simplify your programming time (2 color crossfades, twinkle effects, rainbow effects, etc.)
    Hopefully this gives you one option to look at. Also crossposted to your query in the ETC User Forums.
  • I deal with large LED counts every now and again.  A couple things come to mind -
    1) There is a limit to how much processing your ION is going to be able to handle.  We are currently retooling the performance side of the console line to specifically address this issue - but the ION is the low end of the processor spectrum so it's hard to say.   A GIO is going to be leaps and bounds faster than an ION - especially if you are overlapping Pixel Maps and traditional channel effects
    Last week I did a small-ish LED wall (1.2K) on an ION (not by choice :-) - and it held up pretty well on the 2.1 software.  There were some large movie files in my default library and those caused the system to basically stop working.
    2) If you have ethernet distributed through the house - 4 strategically placed 4 port gateways would take care of the data.  You can enable Artnet on your desk and it will send it out using the 10.XXX IP - from there it's just getting a device to recognize it and convert it over if the lights specifically need 2.XXX.  I use Series 400 Nodes to "Sanitize" my Artnet stream all the time.   So a setup like Console > Node > Media Server works fine whereas Console > Media Server doesn't because the server wont recognize the IP.
    3) Adding a console to the system is possible - but you'll probably end up using midi to fire cues.  To my knowledge there is no way to currently connect multiple ETC consoles together so that they increase the total output of the system and yet operate like 1 console.
    - P
  • Thanks Dennis and Patrick.  PJ - Ion as you know taps out at 3K outputs.  If you add a higher capacity machine (Gio and Eos RPU) to your system, and you are using Ion as a backup, you'd still be limited to 3K (we use the lowest output count between the primary and backup to determine system capacity).   There is a little known potential solution for you - but it would involve controlling the excess LEDs only through the pix map engine.   If you have reached max capacity on your hardware, you can buy (for a really low cost) a 3K "phantom" upgrade.  This will extend the capacity of Ion to 6K - but anything over the 3K threshold can only be patched and control via the pix map engine.
    This concept was conceived as a "get out of jail" for almost free card for situations - primarily rental - when capacity had been exceeded.   But only you can make the judgement as to whether this will work for you.
    Does that make sense?   You can contact ETC technical services for details on this.
    Thanks much!
    a
    [edited by: Anne Valentino at 9:37 AM (GMT -6) on Thu, Oct 3 2013]
  • Thanks Anne!
    Do you have any more information on how the different artnet modes on the console work? I really don't understand them, and am pretty unclear on how to implement them, as far as network setup goes, both settings and hardware.
    PJ
  • Partick,
    It sounds like you are saying for simple chases and color changing that the Pixelmapper built into the console would be more than acceptable, unless I am trying to run super large movie files. is this correct?
    Can you explain your Artnet sanitization scheme a bit more?
    PJ
  • Hey PJ -
    In my experience the ION runs pixel map media of all forms perfectly well until it gets to full size movie files.  So if you have misc HD movies loaded on the desk trying to play those back will noticeably slow down the system - like to the point where all the keystrokes have a 10 second lag.
    All the standard EOS movie files that come with the pix mapper ran fine last week.
    Artnet on the EOS is pretty simple - you turn it on and the console generates Artnet.  Say your console is plugged into your house Network - if you have an Ethernet port onstage and were to plug an Artnet device into it your device should "see" the console's Artnet signal.    As you've mentioned your only problem is going to be the IP range.  Your Artnet devices will probably ignore the console's signal because they are looking for 2.XXX
    So what you need is some network device that will take in the 10.X range and broadcast it from a 2.x address.    I usually have a PRG Series 400 system so I use one of their nodes for this purpose - but only because it's just sitting there and I don't have to configure it.
    Honestly I'm not really a networking guy - like all of us - but I think you can use an NAT (Network Address Translation) enabled router to perform this function.    If you were able to post your specific network setup and the lights in question we could probably find a setup that would work.
    If it were me I'd start by enabling Artnet on the ION and hooking it up to my laptop running Capture or Artnetometer or something like that.  That way you can mess around with it in a controlled environment.
    All of that being said - it may be a better option to purchase an appropriate number of ACN gateways.  It's more plug and play and you wont need to generate both protocols.
    - P
  • Hi PJ,
    Okay, here is a rundown of the settings:
    • Directed Broadcast - the console will send to the broadcast address of its subnet. That is, with a default address for an Ion (10.101.100.101, subnet mask of 255.255.0.0), the console will output its ArtNet traffic to 10.101.255.255.
    • Limited Broadcast - the console will send to a broadcast address of 255.255.255.255. This is limited because routers will not forward broadcast traffic sent to this address.
    • Primary Art-Net - the console will reconfigure its network settings to be compatible with the Primary Art-Net broadcast address (2.255.255.255). This will cause incompatibility in systems where the console has a single network port and other devices are in the ETC standard range. On a multi-NIC (network interface) console like Gio, you can use the second network port to transmit ArtNet data in this configuration, and have your Net3 devices on the first NIC. Keep in mind that this requires two separate networks. The console cannot be connected with both ports to the same network.
    • Secondary Art-Net - the console will reconfigure its network settings to be compatible with the Secondary Art-Net broadcast address (10.255.255.255). This still can cause incompatibility in single-NIC consoles. On multi-NIC consoles, this can still cause issues as the subnets for the ETC default range (10.101.255.255) will overlap with the wider 10.255.255.255 range. In this event, readdressing the other Net3 devices to a 255.0.0.0 subnet mask will be ideal so everything is in the same subnet.
    Generally speaking, we've had success with newer ArtNet devices listening to Directed or Limited broadcast, but the additional options are available in the event you need them.
    Hans
