Gio going to "sleep"
Is there a way to disable or change the time of this feature? Currently working television with 20 minutes of segments before having to touch anything. When start typing again I get frustrated when a keystroke or 2 gets missed in waking up console. I think putting the time to 1.5 hours would also suffice.
Jay
  • Hello, Jay:
    This issue has been resolved with the latest version of the Gio Face Panel Firmware (1.1.9.3).  To install this firmware update, please make sure that you are running v2.0.1 firmware on your Gio.  Then, exit to the ECU by choosing {Exit} from the browser.
    In the settings menu, choose {Maintenance}.  At the bottom of the page, you will see the firmware update utilitiy.  Choose the Gio Face Panel firmware from the list and then choose {Update}.  Follow the prompts.  After the installation you should find that your console no longer sleeps after short periods.
    There are several other updates available.  More information on these updates, as well at the update described above, are available in the Eos Family v2.0.1 release notes: http://www.etcconnect.com/docs/docs_downloads/relnotes/Eos_Family_v2.0.1_RelNote_RevA.pdf
    Thank you,
    Sasha Aranow
    ETC Technical Services
