When I try to edit an intensity palette in blind, hitting the "Edit" softkey takes me to my Magic Sheet tab. If I close the Magic Sheet tab, the "Edit" softkey functions as it should.
[edited by: rstrobel at 12:18 PM (GMT -6) on Sat, Oct 5 2013]
I believe this is a known about bug, you should see it fixed in the next version, the same behaviour occurs with opening the blind edit screen for other locations as well, e.g preset edits.
Note that you don't have to access blind editing for palettes or presets through the list view. You can just go to blind. That will take you to Cue blind. If you just enter IP x Enter - you are now editing that intensity palette.
Hope that helps.
a
