Delete one or all shows on Console
Hej Guys,
my question is, how can I delete a show, or several shows from the console?
My problem is, that there is a very complicated crew situation in my theatre and the showfiles are in my opinionen very complex. So I want to use only my own showfiles and when I'm done, I want to delete this showfile, so that nobody else ist able to use MY SHOWFILE. I went to the CIA and choosed "Delete" and the show is deleted, but not from the console, because I still can reload it again. I want to delete it completely. I read, that this would be possible with the console setup, reached by the shell, but I can't find something like a delete function.
Many thanks,
Dominik
  • hi Dominik
    sorry to hear about your situation.
    you can do what you're looking for in the Browser (in the CIA). go to File > Open > and navigate to your file. press [Delete] and confirm with [Enter]. the file should be gone now.
    to delete more than one showfile in one go: what you're looking for is in the Shell, go to Maintenance > File Manager, choose the files on the left hand side and hit Delete. (or taking a wild guess that you're working with the german version: Verwaltung > Dateimanager, Löschen).
    Grüsse aus der Schweiz
    Ueli
    [edited by: ueliriegg at 7:09 PM (GMT -6) on Tue, Oct 8 2013]
  • Exit to the Shell > Settings > Maintenance > File Manager.
    You can even use the keyboard to select a range of files from your Show Archive using the keyboard [SHIFT] & Mouse click then delete those files.
