Slow 2nd byte in zero count move for I-Cue
**Reposted in the EOS Forum, as the Element Forum seems to get less traffic**
I am running a Rosco I-Cue on an Element console.  I have a large number of bump (zero count) cues that move the mirror a very short distance between two focus palette positions.
Some cues appear to move the mirror quickly to its coarse position with an apparent slower refinement to its proper and final fine focus. This does not happen consistently however--some cues seem to work correctly.
On screen the move simply appears as a zero-count cue with the position value changing instantly.
The I-Cue is in 16-bit mode and the Element is patched with the "I Cue 16B" personality.
For clarity of explanation, my preset pan and tilt values are as follows--
Focus Palette 1: Pan @ -30, Tilt @ -20
Focus Palette 2: Pan @ -11, Tilt @ -21
If anyone can lend any insight to this problem, I would appreciate it.  Obviously I would prefer the movement to appear consistently instantaneous.
Thanks.
