Some questions about Eos programing
Hello,
Here I send you some questions about Eos programming. I hope you can give me a hand on this:
- In Magic Sheets, Is there any way you can block some objects so they can not be edited when in edit mode? I know it sounds like a strange petition, but some of the operators would like to use Magic Sheets modifiying channels but keeping some objects fixed to the background.
- When a time is given to a submaster to FADE In or Out, the motorised fader seems to execute that movement in one go, even if the submaster is still fading. Same thing seems to happen with virtual faders. Could the motorised faders mimic the fade of the submaster?
- We would to install a File server on the same network the Eos consoles are operating (a Primary and a Backup). The reason we want to do that is to be able to record the show files directly onto this hard-disk, as long as it is in the same network. Do you think they can use any multimedia hard-disk with ethernet connector (something like an IOMEGA STORCENTER ix2).
-  When saving a showfile, the console uses the symbol (*) to tell you that file has been modified and it needs saving if you do not want to loose the changes. But some times this symbol appears even if you have just change some manual levels.
Thanks for you help,
Juan Pascual
Stonex, Spain
  • regarding your first question: there is no function like this, but i think it could be done with a transparent image or transparent symbol that is placed in front of the "fixed" symbols but behind the editable ones. haven't tried it though...
  • That could be an option. Thanks, I will try this
  • In Magic Sheets, Is there any way you can block some objects so they can not be edited when in edit mode? I know it sounds like a strange petition, but some of the operators would like to use Magic Sheets modifiying channels but keeping some objects fixed to the background.
    As Ueli noted, this isn't possible at the moment.
    It is by design that the motorized fader goes to the end point right away. It is not possible to change this at the moment.
    Whatever the network storage is, it needs to support a Windows File Share (SMB). Configuration of the NAS would be done on a PC, but after this you would need to map the network drive on the console under Maintenance -> Network Drives.
    I'm not seeing this here. Is there a particular manual change you've noticed that makes this happen?
    Hans
  • Thanks Hans,
    Very helpfull. You are right about the (*) symbol. I think this just appears when there is a new target recorded.
    Take care.
    Juan Pascual,
    Stonex Show lighting, Spain
