Fade FX rate using submasters without Snapping
I am running an absolute LED color effect on an additive submaster slowed to a rate of 10%. If I fire the same effect in a different submaster at a higher rate of 100%, the levels all snap to the beginning of the absolute sequence, instead of just ramping up the speed.
The timing on the fader is 1/H/1.
Timing on the Effect is set to "Cue/Sub."
Entry is set to "Immediate/Fade by Rate." Exit is set to "Fade by Rate."
Is there a way to remedy this?
I have tried running the slow version of the effect on cue instead, and that didn't work.
[edited by: litedesign at 1:56 PM (GMT -6) on Thu, Oct 31 2013]
