Today I found myself wishing I could type "Query Is In Park", but hitting Park cleared the command line. Is there a way to perform the operation I was trying for?
-Jason
-Jason
If you are trying to find out what's parked, why not just hit Park, Park ?.
It later occurred to me that, better than Query Is In Park, a better way to do this would be adding another softkey to Shift+Select Last.
We already have a Select All softkey, and that's probably an easier change in the software than the syntax I was talking about.
Now that Recall From Park is a thing (and what a wonderful thing!) it seems natural to have Select Parked as well.
Hi Jason,
What are you looking to do with the parked channels once you've selected them? One of the most common ones that I can think of is unparking all channels that are in park, but Park Enter Enter will do this.
Hans
is it possible to do Group Park?
Thinking about it, it would be nice to do
Group Park - [Ch] [Enter] [Enter]
Or even [Group] [Address] [Park] [@] [50] [Enter]
I think Group Park would be the most consistent, along with Query Park. Don't agree on Select Park though.
Group Park sounds great to me, less keystrokes is always better.
The things I wanted to be able to do with the channels after selecting them were:
- Recall all the values from park, unpark the channels, and then sneak the parked them back to the underlying values
- In Live, making all parked channels manual, and updating them at those levels into the cue
- Create a preset or submaster with all of the parked values, either in live or blind
It doesn't seem like something you'd need until you have 30 or 40 channels in park and no way to select all of them or create a group of them.
- Jason
Hans.Hinrichsen said:Hi Jason,
Hans
[Recall From][Park] already does everything you're asking for.
Hope that helps,
~P
Crazy - so it does. It never occurred to me to try Recall From Park with no channels selected, but doing so does, in fact, select all parked channels.
It doesn't really make sense, syntax-wise, since typing Recall From Cue 101 both selects the channels and recalls the values, but I'm glad it is in the console.
-Jason
Paul Toben said:[Recall From][Park] already does everything you're asking for.
Hope that helps,
~P
I think the behavior is the same with [Recall From][Park] and [Recall From][Cue][##]. They both select the channels, and make their values manual. In any event, I'm glad it is working for you!
~P
