Greetings,
We have presets where we don't want INTENSITY recorded in. If these are edited in a cue and then the designer wants the preset updated, they likely will now have INTENSITY attached to them. Does anyone know the syntax to update the preset less an attribute such as INTENSITY. I tried, UPDATE PRESET X INTENSITY MAKE NULL, but this is not valid. I know you can edit after the fact in blind or before you record by selecting what you want to include, but a I figured there must be a way to do it as one command string based on excluding.
