ION 1500
EOS 2.1.0 Beta Build 94
We are experiencing the following when running Wybron CXI in Mix mode. The strings will reset to the tail of the string then reset to the proper color. This only happens when a FOLLOW or HANG is encountered. If running the cue sequence with Time Disable the strings do not jump so we know the color is tracking with no change.
Back-grading to the current shipping v2.0.1.9.0.41 golden master corrected the issue.
Also when down grading OS of course you need to uninstall current beta however after the older software installs the console did not automatically restart as it does in a upgrade forward.
Last strange issue. The LCD display screen on the ION's faceplate as well as the encorder wheels failed to function. The LCD display stayed on the large text ION and the encoder wheels proved very course in any Pan Tilt movement. The LCD display returned after a few exits out and back to the shell.
