Hi Anne,
Does this mean the the new version will not support the old RFR? Is there a release date for the new hardware yet?
Malcolm
Hi Anne,
Malcolm
Malcolm, 1.3.1 DOES support the original RFR. We are releasing the new hardware this week (2/28).
Thanks for your patience with this.....
Anne
To be accurate, 1.3.1 support the revised RFR more than the original, as the revised device has another mapping of the buttons that correspond with 1.3.1
But as Anne states, we expect the RFR to pass release this week. It that happen as expected, we should be able to provide you with a replacement unit end of next week, Malcolm.
Regards
Thanks for that info Anne. Is it a complete hardware change for sender and receiver or just the sender
Malcolm
Well, that's a fine question. I'm assuming both the transmitter and the receiver.... if that isn't the case, we will let you know shortly. And, as Erik points out. The Enter button is swapped to the other side of the device.
a
