First Kudos to whoever thought up a way to delete a channel from a cue simply by selecting CHANNEL>DELETE>CUE NUMBER. I found it by accident and that has saved me SO much time with errant programming. Thank you!
Now I know this will fall on deaf ears but several times now I've run into a situation where I need to design an effect and adjust the timing in increments in the one thousands of a second range (.001). I've had shows with multiple effects running at the same time and adjusting the effect by .01 second and then adjusting the overall rate in the cue by 1 or 2% gets it close but not exact. Any ideas?
Thx
