Not sure if this is new to 2.1 or not... [Query] [@] [x] [Sneak] [y] throws an error, but [Query] [@] [x] [Sneak] [Time] [y] works as expected.
2.1.0, Eos 4k
[edited by: JWilsonLX at 10:40 AM (GMT -6) on Thu, Dec 26 2013]
2.1.0, Eos 4k
Not seeing this. This action is two command lines.
Query at value enter
Sneak enter
This syntax works with or without a sneak time, with or without the time button.
Can you clarify the exactly condition and syntax where you are seeing an error?
a
The issue, then, is probably that I'm running this as one command line...
Query @ lvl, then the press of sneak changes my command line to to the channels at that level, as if I had just typed them in myself, then the next press of a number posts after sneak, but without a space(Sneak3), then enter throws the error. In the same situation, If I just add [Time], it works fine as a single command line.
