Tap rate for effects, for Ion
Hi there,
with a lot of pleasure I read in the update of the Ion about some new and improved functions. one of them is the BPM and tap rate for effects.
I was happy to read this but after a while I couldn't find any clou of how I can use the tap rate for effects.
nothing in the supplement and in the software.
can anyone help my?
Jasper Kop
  • hi jasper.
    it's at the very bottom of page 4 of the 2.1 supplement:
    Learning BPM
    If you don't know the desired BPM, you can learn the BPM.
    From Live, with the effect running:
    • [Effect] [1] [Learn] [Time] - posts Effect 1 Learn Time Sample BPM to the command line, and
    opens the effect editor display.
    While in this mode, press [Enter] to establish the BPM. The console will use an average of the last
    four times you press [Enter] in this mode to calculate the BPM. Pressing [Learn] again will stop this
    mode.
    In this mode, every time the BPM changes, a live running effect will be modified accordingly without
    stopping.
  • Here is how BPM works:
    Directly setting BPM
    If you know the BPM, you can assign that directly to the effect by using the {BPM} softkey, which is
    available when in the effect editor display.
    • [Effect] [1] {BPM} [1][9][0] [Enter] - sets the BPM of effect 1 to 190. The step times will be
    adjusted for step-based effects, or the time/dwell will be adjusted for absolute effects.
    The BPM will display on the right side of the effect editor beside the effect number/label. Editing the
    cycle time, the step time for a step-based effect, or the time/dwell for an absolute effect will remove
    the BPM.
    Learning BPM
    mode.
    stopping.
    Learning Discrete Step Time
    In learning discrete step time mode, every time you press [Enter], the time since the last press of
    [Enter]
    is used to set the next step's step time for a step-based effect, or the next step's fade/dwell
    time of an absolute effect.
    • [Effect] [1] [Learn] [Time] [Time] - posts Effect 1 Learn Time Discrete Steps to the command
    line, and opens the effect editor display.
    Pressing [Learn] again will stop this mode.
    Instead of pressing [Enter], you can press [At] while in this mode to add new steps to the end of the
    effect. Pressing [Enter] will send you back to the first step in the effect.
    This explanation comes directly from the 2.1.0 Manual Supplement.  It begins on page 5.  The supplement can be found here:  http://www.etcconnect.com/docs/docs_downloads/manuals/Eos_Family_v2.1.0_Operations_Manual_Supplement_RevA.pdf
    I hope this helps!
    Thank you,
