Altering Columns
This may still be part of an old bug, but. . . .
I love the fact I can now hide columns in the PDS I don't need.  However, Shift Select DOESN'T restore columns if those columns are on the second screen.
(IE I've expanded the cue list to cover both screens verically (cues 1 - 50 on screen 1, adn cues 51 - 80 on screen 2)).
I can adapt and restore the columns on screen 1.  I then need to alter the columns again on screen 2, since the first column change doesn't transmit to the second screen. (can this be fixed so I only alter the Rate and Link columns once?)
Shift Select will restore screen 1, but I can't restore screen 2.  Snapshots don't work either to restore columns.  Only a console power on/off will fix screen 2.
Note: changes made to the columns will survive a snapshot refresh command (load snapshot 3, make column changes, load snapshot 3, the changes remain).
Changes made to the columns will NOT survive going to another snapshot and then coming back.  It recalls the whole snapshot properly (except for screen 2)
Note to other users: if running with PSD on a screen, and channels on the other, Shift Select when the PSD is selected/tabbed to.  That will restore the PSD.  If you Shift Select while the channel screen is selected, it alters your view of the channels (zooms in) and running snapshots doesn't seem to fix it.
Andrew Riter
