2.1 RVI Display issue
Hi again.
RVI, just updated to 2.1.  (the OS is  1.4.2.9.0.3)
Screen resolution set to the largest available (1024x768).  Using a NEC AccuSync LCD 51v monitor.
with the change to the SK display in the lower right of the screen, the buttons now extend further left.  The first button ( Blank command line: Query) is cut off by half.
The cut off line corresponds to the vertical margin of the Display Browers and NP button field.  It's as if the buttonfield, and the IFCB column footers are overlapping and sitting on top of the SK buttons.
I think this is new, with the addition of the larger (?) button graphics and text?  I don't usually look at the RVI, since I'm at the console.
Andrew Riter
Chan Centre for the Performing Arts.
