Print patch but only Show Channels
Hej everybody,
in my theatre it's very common that an host operator brings his own console and he doesn't know my patch before. So we use our console ( GIO 2.1) for doing the focussing and I'm writing down, which channel is used in a paper patchlist. But the Gio has the FLEXIVIEW 'Show channels'. Can I use it in a sort of way to ONLY print a the patch oft these channels? What I mean is printing a patch of only these Channels who appear in the 'Show Channel' Flexiview?
Many Thanks to everybody,
Dominik
  • Hi Dominik.  At the moment, print patch will print any devices defined, with or without an output address.  However, adding [Used in Show] as a print filter is a terrific idea - applicable to elements other than just patch.  Will add to the list.
    You can add to your print patch, print show channels.  That will give you a list of channels that are used in the show and those that are not to use as a cross-reference with your patch data.
    Thanks much,
    Anne
    [edited by: Anne Valentino at 7:55 AM (GMT -6) on Thu, Jan 16 2014]
