AutoMark
If a cue list is completed with AutoMark off then AutoMark is turned on at a later time, will it go through the cue list and Mark where appropriate or does AutoMark need to be turned on while creating the cue list?
If It does not Mark, then if every cue that needs to be Marked is manually Marked, will that work or again, does Mark need to be done while creating the cue?
If all else fails then would all fixtures that need to be set in the cue prior need to be manually added in the prior cues with intensity off to create the same results?
Recorded a 101 cues show yesterday and didn't realize AM was off.  Aaaarrrrggggg!!!!  Fortunately Dress Rehearsal not until Tuesday.
