ION Software 2.1 Issues
So the issue I was having with the back button function is happening again.  I can go forward through cue stacks but when I press the back button nothing happens.  The cue shows that it is going backwards through the stack but the changes are not happening.  Also, if i NEXT to a different cue in a stack then LOAD it, it will not activate/take that cue. Very odd and very annoying. Is there a way I can send someone the file and have them take a look at it?
In all the Cue stacks that are not working correctly I have NO intensity data.  If I put the moving lights at 01% and update the cue, that fixes the problem with the back button and pre loading the cues.  In my opinion this is a major flaw with this update. Do you agree?  Is there another workaround or something that i'm missing?  I really don't want to be sending a 01% intensity signal to all my movers all the time.
