Hello
I have a Cue with effect running loaded into a Sub. When I press the bump button I want just that sub/effect to run and all other lights to go out. Like the old 'solo' flash button. Is that possible on EOS?
Geoff
Hello
Geoff
Hi Geoff,
There may be a solo function that I'm unaware of, but a work around. Set your Sub as LTP. Edit your sub and so that every channel in your show except for the ones you want on have a hard 0. So when you raise the sub (bump button), those channels go to 0.
I know this works with a regular LTP sub. Unsure about an effect sub.
