I think there is a behavior change on the way sneak and capture interact. Previous to 1.3.1 if I used the capture button on parameter data in a channel, then used sneak on that channel, the channel would revert to the background or original cue or sub levels. If I used sneak "globally" without specifing channels, then the data would not revert to the background levels after being modified and held by capture. Now it appears that if there is a background level for the channels that I have captured in a cue and modfied from the cue, then a global sneak will revert those back to the cue levels.
So, I am not sure this is a new bug or just a correction on an old bug, but I liked it better the old way with sneak having a different effect on captured channels depending on the targets on the command line.
So, how is it supposed to work?
Mike
