High resolution monitors on Eos Ti
Has anyone had any experience with using high resolution (2560x1440) external monitors on the Eos Ti?
I notice a wiki page mentions the maximum resolution when using DVI single link (and VGA) but makes no mention on whether you can go higher using a DVI-DL cable. I'd rather avoid converting down to analog for the higher resolution...
The reason I want to run at 2560x1440 is so I can maintain a similar ppi or detail to what I'd have on a smaller monitor but across a much larger screen.
Wiki page: http://www.etcconnect.com/community/wikis/products/maximum-resolution-of-gio-ti-and-cobalt-consoles.aspx
Cheers, Blake.
