Cuelist display info
Hi there
As has been raised before, cue text label and external links are not visible on the onboard monitor of an eos.  As has been stated, the current work around is to hook up an external monitor of higher resolution.  This works really well, except for trying to read snapshots in the external links column.
Effects are listed in the External links column as "E6" or whatever number it is, however snapshots are displayed as "Snapshot 361" and all you get is  "Snapshot 3..."
If it's not already on the list, would it be possible to abbreviate snapshot to something smaller?
Cheers
