How can i see the used chanels in show, without 0%?
Hi!
Sorry for my bad english! I use an Gio. In the "show only" window, i see the chanels, what i use in the show. But i don't want see the chanels, which i used only 0% in the show.
So, i want see the used chanels just over 0%.
Is it possible?
[edited by: brems at 2:54 AM (GMT -6) on Sat, Apr 5 2014]
  • for the console every channel that has a hard value somewhere is part of the show, even if this hard value is 0%.
    there are two ways: clean up the blue 0 values, or instead of Flexi Show use Flexi ViewChannels. [Group] [Cue] [1] [Thru] [Flexi]&{Softkey 6}. but be careful, if you later add new channels to the show, you will have to adapt your Flexi ViewChannels to the new channels, or else you will only see them if they're selected.
    the chances, that with the second method you end up with a channel that is on onstage but not on your screen (which can be quite confusing... ;) ) are quite high, that's why i'd rather suggest method one... to do that you go to Blind, select a cue, find the blue zeros and At Enter the values. or you use Cue 1 Enter, Query IsIn Cue - Group Cue Enter At Enter. and to clean all the cues at the same time: Blind, Cue 1 Thru Enter, Query IsIn Cue 1 Thru - - Group Cue 1 Thru Enter At Enter.
    [edited by: ueliriegg at 4:36 AM (GMT -6) on Sat, Apr 5 2014]
  • What is the softkey 6 ?
    (edit: I found)
    [edited by: brems at 5:49 AM (GMT -6) on Sat, Apr 5 2014]
  • The View Channels flexi is the best for me. Thanx.
