Hello Everyone,
Has anyone ever used a macro to turn on and off MIDI on the ION Console. It would be turning on and off 'Show Control' I'm thinking.
Hello Everyone,
just tried this. it works. i suggest Learning it, then editing. you can clear out some stuff and will have to manually insert an "Enable".
now my macro looks like this: Setup MSC_Receive Enable Live *
We have Macro's that turn on and off Midi throughout the show, so the receive is only enabled for exact moments in time when we want, just incase other departments get a little trigger happy.
These macro's are executed from the cue stack usually the cue before the midi is to be fired.
You don't need the 'Setup' or 'Live' from memory Uellriegg.
Macro 1 - MSC_receive Enable •
Macro 2 - MSC_receive Disable •
I also have them for all the Analog Inputs, MSC Transmit and RFR Enable Disable.
sammy, you're right
i took a wrong conclusion from my setup ManualTime macros, where you do need the Setup.
Hey,
Thanks for getting back to us so soon.
Under the editing macro menu we can't find the MIDI Show Control (MSC) Button. We do have a MIDI Button. Do we possibly need an update?
Thank!
