EDIT - Repost
So I posted a year ago in regards to syncing songs with midi cues via my laptop. http://www.etcconnect.com/Community/forums/p/9610/38387.aspx#38387
I finally got around to it this year and bought a usb to midi adapter on amazon and I'm using FL studio 11 with a third party app called midi mapper x. (I have access to ableton if needed, however I don't know how to use it)
I mapped the board to recieve midi only and connected to my computer. FL Studio detects it as usbmidi 2.0 and I set the output on it to port one, and setting the msc recieve on the board as 1. (Midi cue list is blank, should i put a value like 1 in it?)
The program setup looks like this. http://puu.sh/8ctae/2c3c31d967.png.
I am currently using an ETC ION lightboard running the latest firmware if i recall correctly.
I send the hex code to the board however the board isn't changing cues or changing the master to 50% as the code states. I even tried to change the code to say send to all devices (I assume the board is device 1 as it's the only board on the network.)
Anyone have experience with sending MSC like this? Thanks.
1. Are the codes always in this format? Someone stated that there are direct commands, I only need the GO command.
2. Maybe I should try using String MIDI TX? Will that work over the usb to midi cable?
[I will take more pictures of the setup when I get back to the board later today]
Thanks in advance.
[edited by: APhamX at 7:02 PM (GMT -6) on Sun, Apr 20 2014] repost
