Feature request for [Next] / [Last]
Maybe we could extend the [Next] / [Last] button functionality a little  to improve hopping around in channel selections?
Currently if I have a channel selection of [1] [Thru] [100] [Enter], if I press [Next] / [Last] I will be able to move around inside of that channel selection to select which channel I am controlling while still holding that selection.
But say I would like to hop from 1 to 51 while still keeping this selection intact, I would have to [Next] 50 times or hold the [Next] button until i reach my desired channel (if I am correct in understanding the current state of moving around inside of a channel selection).
I purpose having the [Next] / [Last] key be able to be held to hop x amount of channels, much like holding [FaderPage] works for selecting which page your faders are on
This would change the keystrokes in this example from 50 [Next] presses or Hold [Next] and wait until you have reached your selection, to Hold [Next] [51] [Enter].
This could possible be used for cues/subs/anything next is already used for as well?
Potential problems I see with this are: Flexi mode options, If next hop is out of the defined range, and if next option isn't valid in defined context.
