ION and Series 2 Lustre
Hello. I am using an Ion with the most recent software. I recently purchased some Series 2 Lustre LED Source Four fixtures. What is the best selection for address "type" in the patch? Thank you
  • i might be wrong, but you will need to use one of the HSI personalities in ETC Selador > S4 LED Lustr+ until the next version of the Eos software is released and it understands how the new lime led works. since with the HSI modes not the console but the fixtures does the calculation of the color, you should have a pretty good chance of getting away with it. HSI, HSI Fan, HSI Strobe and HSI Strobe Fan depending on your needs should be a safe bet.
    i guess for the modes where the console needs to know about the leds' colors, like all +7 and the Direct modes, you will need to wait some weeks until 2.2 is released.
  • Keep in mind that with the HSI modes, you won't be able to make live fades between colors the way you're probably expecting.  Fading in Hue/Saturation space is a bit strange.
    I would patch the fixtures in direct mode and ignore the color picker/gel library until the profiles are released, but the best thing to do is to patch the fixtures both ways and play around.
    ~P
