I have connected the appropriate model Elo touchscreen to an RVI, but I can not seem to find any way to calibrate it. I find utilities with Ion for calibrating a touchscreen but not on the RVI. Can anyone help with this?
Hi Mike,
Currently, only the Ion console comes with Elo touchscreen drivers pre-installed. That means you will have to manually install the drivers yourself, and then you will see the calibrate button in the welcome screen. If you need specific instructions on how to do this, simply email eos@etcconnect.com and I will reply.
(In Eos 1.4, all consoles will come with these drivers per-installed)
