offline effect control
How can the effects be controlled in the offline software? Delay, Rate, Size, H Form, etc. Can't find anything on my shortcut keys sheet. Found Delay Shift D which seems to populate the command line properly but didn't use it. Found Rate Shift R but all that does is toggle rate on and off in small blue print in the Master section of the Playback Status screen. Didn't find the others.
