Under Network Settings-Output Protocols (with V2.2), I no longer see the check box for Output to Visualizer from offline. Have I over looked where this is?
The offline boot up option now include offline and offline w/ viz. So you no longer need to enable this is the shell.
Once you've chosen your OS (Eos family or Element), when the client or Nomad dongle is not installed, you will see those two options to start up.
Hope that helps,
Anne
