Hi there!
I have an old show with a bunch of color-palettes by type, want to merge them into my new show, but the original channel number is now used for something else.
Is there a fast way, to get my palettes onto my new channel-number?
Hi there!
i guess the easiest would be to edit the old showfile: load it, in Patch: Chan x MoveTo y Enter (where x is the by type channel in the previous showfile and y is the soon to be by type channel in the new showfile). this changes not only the patch but also changes the by type channel in the respective palettes. save this showfile.
now load your new show again and merge.
this should work...
Add your new channel in the old showfile.
Open the color palette list view. [Color Palette] 1 Thru 1000 Enter {Edit} Old channel Copyto New Channel Enter New Channel number {By Type}
This should change the By Type driver in that range of palettes. While your editing all those palettes - remove any other channels you don't want merged into your new showfile.
Now you can merge those palettes in with the correct channel.
(or Uli's method :-)
Got it!
couldn't load the old show, because it's quite busy on stage right now, and I need to be online with the console.
but the fixture with my old number is not here yet :D so I patched it as my old fixture, merged my palettes and then did the edit.
Everything is beautiful now.
Thanks! :)
