Is it possible to make a single channel delay in a cue. ie: cue 5 has 5 second time however I want channel 5 to have a 10 second time.
Hi
Ok i find this function but how can we see what's in discrete timing, is there a window like on COBALT where we can see that?
Best
That's the main problem with Discrete Timing. It's difficult to see the timing on individual channels. but it's not impossible. If you press the [Time] DISPLAY button.... or the [Time] command button + [About], your Discrete Timing will display. Check out the Learning Series Video on Discrete Timing.
But if you're just doing one or two channels, a better option is to use a Multi-Part Cue. A multi-part cue will display all of the timing details in the PSD window. Each part can have its own timing including delays.
Super.. It work..
