Ian Scott
Posted: Sunday, July 20, 2014 2:20 AM
Hi
I I'm doing a show where I need 4 universes of DMX/Artnet, I have access to two Ion 1K's, am I able to use one to run the show and the other for the next two universes. I'm trying to avoid programming on two consoles then having to press the go buttons at the same time or running MIDI to both consoles.
Ian
ueliriegg
Posted: Sunday, July 20, 2014 7:25 AM
no you can't. licenses don't add up when you network consoles.
just to make sure: are you aware that 1k doesn't mean you can only access two universes. it means that you can output to 1024 addresses no matter across how many universes they're spread.
