Can Nomad on PC/MAC use Net2?
A Nomad dongle was recently acquired to be used as a backup to Ion in a system with many Net2 Nodes (installed and portable).  In testing out the system, the Nomad would not control anything over EDMX.  In PC version, there is no way to select EDMX in the shell settings. The box is grayed out.  In Mac, the shell settings allow you to select/check EDMX, however as soon as you hit accept and return back to the settings, the EDMX box is unchecked.
This proved problematic as Nomad cannot be used to backup this system.  Is there any discussion about adding Net2 in future (I realize how backwards that sounds)?  This is a big flag for those systems who are updating consoles but not the node/gateway infrastructure.
Thanks.
